Is my 9900K not stable? crash in battlefield 5 without error
22 Mar 2017
Poland
Hi my pc.
9900K stock turbo 4.7 . All auto settings in bios. VOLTAGE on AUTO.
Noctua NH-D15 .Temps 60-70C
2x16 GB DDR4 GSKILL 3000 XMP
Corsair 850RmX
Aorus 2080 Ti Xtreme , no oc,stock.
All stress tests passing fine. I dont have any crashes in game.
But few days ago, i go out to work, and i left running game BF 5. When i back,game was running 13 hours,and in 14 hour ( it was 3 am ) it crashed to desktop. Event viewer nothing said. No error message,no display crash. Just exit to desktop.
Game just was on 14 hours,and after moment it go to desktop withour error message. I dont touch anything,game was in campaign mode,when character is standing on the same place.
Now i am testing again and see if i can reproduce, but i cant. I am currently on 80 hour and not crashed again.
Is this reason to worry?My drivers are the newest.
Maybe XMP issue or auto voltage? Or issue with game?
Battlefield is very sensitive to even slightly unstable overclock that pass all other tests, usually it will crash to desktop with no error report.
The game is also still rather buggy so it could just be a problem with that.
Probably random. Maybe a bug in the game. 14 hours is a long time to leave a game running :).
Just see how things go. A 9900K system I have froze the other day, just after a browser became slow and closed unexpectedly without warning. One-off so far. Running stock too. Tried overclocking but decided not worth it for 6% all core improvement given my uses.
Games crash sometime, no biggie. I'd forget about it and move on. Only get concerned if you get repeated similar crashes.
Why would you leave it running when you went to work, just shut it down and save your electricity bill?
I remember Overwatch ****** me off so much last summer with random crashes. When you have a non-stock CPU and GPU it's difficult to narrow down issues, and after much testing it turned out to just be an issue with the combination of an Overwatch patch and newer AMD drivers. Sometimes it's not your fault! :p
But i have found dump file in battlefield 5 folder this:
Here is log:
0:016> !analyze -v
* Exception Analysis *
*** WARNING: Unable to verify timestamp for dbdata.dll
KEY_VALUES_STRING: 1
Key : AV.Dereference
Value: NullClassPtr
Key : AV.Fault
Value: Read
Key : Analysis.CPU.Sec
Value: 5
Key : Analysis.Elapsed.Sec
Value: 131
Key : Analysis.Memory.CommitPeak.Mb
Value: 204
Key : Timeline.Process.Start.DeltaSec
Value: 49516
PROCESSES_ANALYSIS: 1
SERVICE_ANALYSIS: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
Timeline: !analyze.Start
Time: 2019-06-09T17:06:57.933Z
Diff: 663944933 mSec
Timeline: Dump.Current
Time: 2019-06-02T00:41:13.0Z
Diff: 0 mSec
Timeline: Process.Start
Time: 2019-06-01T10:55:57.0Z
Diff: 49516000 mSec
DUMP_CLASS: 2
DUMP_QUALIFIER: 400
MODLIST_WITH_TSCHKSUM_HASH: ecae460c3b09697da4b7d808edddb7af9cabb419
MODLIST_SHA1_HASH: b436539aa6f3750791d04ac1da7f12b3daf8b6e7
COMMENT: Frostbite MiniDump. Address: 0000000145DE184D (In Windbg type: .ecxr)
[EOF]
NTGLOBALFLAG: 0
PROCESS_BAM_CURRENT_THROTTLED: 0
PROCESS_BAM_PREVIOUS_THROTTLED: 0
DUMP_FLAGS: a2
DUMP_TYPE: 11
CONTEXT: (.ecxr)
rax=00000000abd23ce0 rbx=00000000accc5820 rcx=0000000000000000
rdx=0000000000000000 rsi=000000000055fd80 rdi=0000000033fe2710
rip=0000000145de184d rsp=0000000033fe1a00 rbp=0000000033fe1be0
r8=0000000000000006 r9=0000000000000001 r10=0000000000000006
r11=0000000033fe1a68 r12=0000000000000000 r13=0000000000000000
r14=ffffffffffffffff r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010246
bfv+0x5de184d:
00000001`45de184d 488b5238 mov rdx,qword ptr [rdx+38h] ds:00000000`00000038=????????????????
Resetting default scope
FAULTING_IP:
bfv+5de184d
EXCEPTION_RECORD: (.exr -1)
ExceptionAddress: 0000000145de184d (bfv+0x0000000005de184d)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 0000000000000038
Attempt to read from address 0000000000000038
DEFAULT_BUCKET_ID: NULL_CLASS_PTR_READ
PROCESS_NAME: bfv.exe
FOLLOWUP_IP:
bfv+5de184d
READ_ADDRESS: 0000000000000038
ERROR_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 0000000000000038
WATSON_BKT_PROCSTAMP: 5047ff9c
WATSON_BKT_MODULE: bfv.exe
WATSON_BKT_MODSTAMP: 5cdbc3d7
WATSON_BKT_MODOFFSET: 5de184d
WATSON_BKT_MODVER: 1.0.72.44435
BUILD_VERSION_STRING: 17763.1.amd64fre.rs5_release.180914-1434
ANALYSIS_SESSION_HOST: DESKTOP-RVP2EUM
ANALYSIS_SESSION_TIME: 06-09-2019 19:06:57.0933
ANALYSIS_VERSION: 10.0.18869.1002 amd64fre
THREAD_ATTRIBUTES:
OS_LOCALE: PLK
BUGCHECK_STR: APPLICATION_FAULT_NULL_CLASS_PTR_READ_NULL_CLASS_P TR_DEREFERENCE_INVALID_POINTER_READ
PRIMARY_PROBLEM_CLASS: APPLICATION_FAULT
PROBLEM_CLASSES:
Type: [@ACCESS_VIOLATION]
Class: Addendum
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Type: [INVALID_POINTER_READ]
Class: Primary
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Type: [NULL_CLASS_PTR_DEREFERENCE]
Class: Primary
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Type: [NULL_CLASS_PTR_READ]
Class: Primary
Scope: DEFAULT_BUCKET_ID (Failure Bucket ID prefix)
BUCKET_ID
Data: Omit
PID: [0x28cc]
TID: [0xb30]
Frame: [0] : bfv
IP_ON_HEAP: 0000000000400000
The fault address in not in any loaded module, please check your build's rebase
log at <releasedir>\bin\build_logs\timebuild\ntrebase.l og for module which may
contain the address if it were loaded.
FRAME_ONE_INVALID: 1
LAST_CONTROL_TRANSFER: from 0000000000400000 to 0000000145de184d
STACK_TEXT:
00000000`33fe1a00 00000000`00400000 : 00000002`145b8ca0 00000000`0055fd80 00000002`188990d0 00000000`00000000 : bfv+0x5de184d
00000000`33fe1a08 00000002`145b8ca0 : 00000000`0055fd80 00000002`188990d0 00000000`00000000 00000000`00000000 : 0x400000
00000000`33fe1a10 00000000`0055fd80 : 00000002`188990d0 00000000`00000000 00000000`00000000 00000000`33fe2710 : 0x00000002`145b8ca0
00000000`33fe1a18 00000002`188990d0 : 00000000`00000000 00000000`00000000 00000000`33fe2710 00000001`45e11736 : 0x55fd80
00000000`33fe1a20 00000000`00000000 : 00000000`00000000 00000000`33fe2710 00000001`45e11736 00000000`00000006 : 0x00000002`188990d0
THREAD_SHA1_HASH_MOD_FUNC: f86e706f3881ff99410f64522468510881cb97a0
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: fc53bee7bd5eee7c273e1f674a644f5504b35eba
THREAD_SHA1_HASH_MOD: f86e706f3881ff99410f64522468510881cb97a0
FAULT_INSTR_CODE: 38528b48
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: bfv+5de184d
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: bfv
IMAGE_NAME: bfv.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 5cdbc3d7
STACK_COMMAND: ~16s ; .ecxr ; kb
FAILURE_BUCKET_ID: NULL_CLASS_PTR_READ_c0000005_bfv.exe!Unknown
BUCKET_ID: APPLICATION_FAULT_NULL_CLASS_PTR_READ_NULL_CLASS_P TR_DEREFERENCE_INVALID_POINTER_READ_bfv+5de184d
FAILURE_EXCEPTION_CODE: c0000005
FAILURE_IMAGE_NAME: bfv.exe
BUCKET_ID_IMAGE_STR: bfv.exe
FAILURE_MODULE_NAME: bfv
BUCKET_ID_MODULE_STR: bfv
FAILURE_FUNCTION_NAME: Unknown
BUCKET_ID_FUNCTION_STR: Unknown
BUCKET_ID_OFFSET: 5de184d
BUCKET_ID_MODTIMEDATESTAMP: 5cdbc3d7
BUCKET_ID_MODCHECKSUM: ef4e508
BUCKET_ID_MODVER_STR: 1.0.72.44435
BUCKET_ID_PREFIX_STR: APPLICATION_FAULT_NULL_CLASS_PTR_READ_NULL_CLASS_P TR_DEREFERENCE_INVALID_POINTER_READ_
FAILURE_PROBLEM_CLASS: APPLICATION_FAULT
FAILURE_SYMBOL_NAME: bfv.exe!Unknown
TARGET_TIME: 2019-06-02T00:41:13.000Z
OSBUILD: 17763
OSSERVICEPACK: 475
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 256
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt SingleUserTS
USER_LCID: 0
OSBUILD_TIMESTAMP: 1989-09-10 08:58:46
BUILDDATESTAMP_STR: 180914-1434
BUILDLAB_STR: rs5_release
BUILDOSVER_STR: 10.0.17763.1.amd64fre.rs5_release.180914-1434
ANALYSIS_SESSION_ELAPSED_TIME: 2033c
ANALYSIS_SOURCE: UM
FAILURE_ID_HASH_STRING: um:null_class_ptr_read_c0000005_bfv.exe!unknown
FAILURE_ID_HASH: {f476daa4-68b6-2895-45dc-838c7fe6b3de}
Followup: MachineOwner
0:016> !analyze -v
Value: NullClassPtr
Key : AV.Fault
Value: Read
Value: 1
Value: 1
Value: 211
Value: 49516
SERVICE_ANALYSIS: 1
Time: 2019-06-09T17:09:09.843Z
Diff: 664076843 mSec
Diff: 0 mSec
Diff: 49516000 mSec
DUMP_CLASS: 2
DUMP_QUALIFIER: 400
[EOF]
NTGLOBALFLAG: 0
DUMP_FLAGS: a2
DUMP_TYPE: 11
CONTEXT: (.ecxr)
bfv+0x5de184d:
FAULTING_IP:
bfv+5de184d
NumberParameters: 2
FOLLOWUP_IP:
bfv+5de184d
ANALYSIS_SESSION_TIME: 06-09-2019 19:09:09.0843
THREAD_ATTRIBUTES:
OS_LOCALE: PLK
PROBLEM_CLASSES:
Class: Addendum
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Class: Primary
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Class: Primary
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Class: Primary
BUCKET_ID
Data: Omit
PID: [0x28cc]
TID: [0xb30]
Frame: [0] : bfv
STACK_TEXT:
MODULE_NAME: bfv
IMAGE_NAME: bfv.exe
OSBUILD: 17763
OSSERVICEPACK: 475
OS_REVISION: 0
SUITE_MASK: 256
PRODUCT_TYPE: 1
OSNAME: Windows 10
USER_LCID: 0
ANALYSIS_SESSION_ELAPSED_TIME: 76d
ANALYSIS_SOURCE: UM
0:016> !analyze -v
Value: NullClassPtr
Key : AV.Fault
Value: Read
Value: 1
Value: 1
Value: 219
Value: 49516
SERVICE_ANALYSIS: 1
Time: 2019-06-09T17:09:11.746Z
Diff: 664078746 mSec
Diff: 0 mSec
Diff: 49516000 mSec
DUMP_CLASS: 2
DUMP_QUALIFIER: 400
[EOF]
NTGLOBALFLAG: 0
DUMP_FLAGS: a2
DUMP_TYPE: 11
CONTEXT: (.ecxr)
bfv+0x5de184d:
FAULTING_IP:
bfv+5de184d
NumberParameters: 2
FOLLOWUP_IP:
bfv+5de184d
ANALYSIS_SESSION_TIME: 06-09-2019 19:09:11.0746
THREAD_ATTRIBUTES:
OS_LOCALE: PLK
PROBLEM_CLASSES:
Class: Addendum
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Class: Primary
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Class: Primary
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Class: Primary
BUCKET_ID
Data: Omit
PID: [0x28cc]
TID: [0xb30]
Frame: [0] : bfv
STACK_TEXT:
MODULE_NAME: bfv
IMAGE_NAME: bfv.exe
OSBUILD: 17763
OSSERVICEPACK: 475
OS_REVISION: 0
SUITE_MASK: 256
PRODUCT_TYPE: 1
OSNAME: Windows 10
USER_LCID: 0
ANALYSIS_SOURCE: UM
I tried to reproduce this but i cant. I left game running 3xtimes for 20 hours and nothing again,game is runnin.
Thx
I see it like this: there is no such thing as perfectly stable, just stable enough for you. I'm certain my 8700K overclock would fail a 12 hour Prime95 test. But I never get crashes under normal use, so who cares?
A rogue solar ray could penetrate a memory module and cause a blue screen - should you only run ECC RAM? No. Because on a gaming machine it really doesn't matter.
Your game of battlefield crashed after 14 hours. It was probably a rogue error. Just go back to playing and if it happens again investigate the problem.
Hey. Somebody said this to me:"Try to slightly increase your DRAM Voltage (something between +0,015v and +0,050v)! I would bet that the problem is solved after that. I saw a few users before having exact the same problem with the Hero XI and G.Skill Ram as u. Please inform us if it worked!"
So listen to him or not? Also memtest 86 8.2 no errors 4 passes, TEST RAM no errors overnight. REALBENCH no issues.
Also in game 100 hours no crash again.
