- 12 Feb 2013
- Cumbria
I've had a fractal s36 in my system since 2018, the other day I came back into my room and the system had restarted (I have auto updates etc off).
I looked on event viewer which said the system rebooted unexpectedly so I decided to check the temps.
My idle temps are fine so I ran cinebench and basically straight away the cpu package went to 100 and core 1 and 3 went to 100 so I stopped cinebench.
I have applied thermal grizzly twice now to see if it help but I am still hitting 100c as before.
There is a little noise which I think is the pump.
My cpu was a delidded one from overclockers
Do you guys think my aio is dead, hardware monitor says cpu fan speed 2860 rpm
my specs
fractal r6
fractal s36
32GB corsair dominator
8700k clocked to 5GHz
980 NVME
1TB ssd
2TB wd
1080Ti gigabyte
seasonic m12 750w
my specs
fractal r6
fractal s36
980 NVME
1TB ssd
2TB wd
1080Ti gigabyte
seasonic m12 750w
