just wandering if mu case is big enuff to fit a GeForce 8800 GTS in it.
http://www.jeantech.com/achillis.htm
heres the spec too
Product Name
Achilles JNA3030 BK/BL/RD
Manufacturer's Part Number
JNA3030 BK/BL/RD
Form Factor
Micro ATX and ATX from factors
Weight
7 kg
Dimensions (WxDxH)
200x500x437mm
Manufacturer Warranty
1 years warranty
Product Description
ATX tower gaming case
Side Panel window
Yes
Fans Included
2 x 80mm LED case fans+ 2 x 120mm blue LED fans
Front USB ports
2
Front Firewire (1394) ports
_
Front Audio/Mic ports
Yes
Fan speed control
No
Power Supply
NO
N.W/G.W
7kg/8kg
Height
437mm
Width
200mm
Depth
500mm
Expansion slots
7
Total Drive Bays
10
5.25 Drive Bays
4
3.5 Drive bays
2
Total fan space
5
Top panel with window
Yes
Construction
0.7mm SECC rust proof Galvanize steel
Compatibility
Micro ATX and ATX motherboards
Form Factor
ATX/micro
3.5 Drive Bays (Hidden)
4
Total fan space
5
heres the spec too
Product Name
JNA3030 BK/BL/RD
Form Factor
Weight
7 kg
Dimensions (WxDxH)
200x500x437mm
1 years warranty
Product Description
Side Panel window
Yes
Fans Included
Front USB ports
2
_
Yes
Fan speed control
No
Power Supply
NO
N.W/G.W
7kg/8kg
Height
437mm
Width
200mm
Depth
500mm
Expansion slots
7
Total Drive Bays
10
5.25 Drive Bays
4
3.5 Drive bays
2
Total fan space
5
Yes
Construction
Compatibility
Form Factor
ATX/micro
4
Total fan space
5
