Is my chosen PSU enough to power this spec?
14 Jan 2013
London
Hey guys, just ordered all my stuff for my new set up I have run it through a few online power supply calculators to see how much power I need but each one are slightly different.
I have gone for:
CORSAIR GAMING SERIES 2013 EDITION 700W
Would you guys be able to tell me if this psu is enough to power the following?:
CPU: INTEL CORE I7 3770K 3.5GHZ IVYBRIDGE
GPU: ASUS HD 7970 MATRIX PLATINUM 3072MB GDDR5
Monitor: ASUS VN247H 24" WISESCREEN LED BLACK SUPER THIN BEZEL
Case: NZTX PHANTOM 410 MIDI TOWER CASE BLACK WHITE TRIM
SSD: CORSAIR FORCE SERIES 3 120GB SATA 2.5" 6GB/S
Keyboard: ROCCAT ISKU ILLUMINATED GAMING
Motherboard: ASUS MAXIMUS V GENE Z77 SOCKET 1155 MATX
Memory: CORSAIR VENGEANCE 16GB 4x4GB 2133MHZ DDR3
Optical Drive: SAMSUNG 24X DVD WRITER SATA
OS: MICROSOFT WINDOWS 8 64BIT
Radiator Fan: CORSAIR SP120 120MM HIGH PRESSURE FAN x2
Reservoir/Pump: XSPC X20 750 DUAL 5.25 BAY RESERVOIR PUMP
Waterblock: XSPC RAYSTORM CPU WATER BLOCK
HDD: SEAGATE BARRACUDA 2TB 7200RPM SATA 6GB/S 64MB CACHE
Thanks guys :)
Thanks guys! I really appreciate the fast response. I was getting all worried because one calculator site said it was not enough :( I will post up my build log once I get started!
I would get a 750W so that I have a little bit of headroom to be honest, but 700W should be fine, as should a well branded 650W (XFX, Corsair, Seasonic, Silverstone etc etc).
For the price, I would get this one. Better PSU on the whole, higher quality internal components, modular design, 50W more power. http://www.overclockers.co.uk/showproduct.php?prodid=CA-013-XF The Corsair one should be at least £10 cheaper with that bad boy around.
