- 16 Apr 2016
Hey,
My desktop is driving me crazy and I'm hoping you guys will know what I should do
I built it a good few years ago. It's got a Gigabyte Z68X-UD3P-B3 motherboard, an i5 processor, 6GB of RAM and an AMD Radeon HD 6980. It's in a HAF case.
I was using two really old hard-drives, so it did check-disc every time I started up, on both drives. It would always freeze in the same place. I figured they were just too old and bought a Samsung EVO 500GB SSD last week, which I installed, and downloaded Windows 10 64-bit.
It doesn't seem to have fixed the problem...Neither case button works properly to turn off the machine, both the "off" button and the "restart" button just restart the computer. It always fails the first restart tried with those buttons. It gets down to the "Memory Frequency" part of the start-up screen and then restarts. Second time it starts up fine. It always starts up fine if I tell the computer to turn off/restart. It turns on fine using the "on" button, too.
I installed the Gigabyte app centre yesterday and let it update all the drivers it felt it needed. It downloaded a few then started blue-screening on start-up, with the error "System Server Exception." I had to totally format and reinstall Windows.
I've done the Windows memory test, it seems fine. I've tested all the RAM sticks one by one, and the start-up error happens on all of them... I could replace them but I'm worried that won't fix the problem.
It's a lovely machine when it's on and working! I can use it all day and it'll be fine.
Thanks
Thanks
