So this is my pc currently. It's running a Asetek 240mm 570LX Thick Radiator as the front intake and has the standard 120mm Phanteks Eclipse P350X extractor on the rear.
So my question is; when i'm gaming and it's slightly more demanding (witcher 3 is a great example), my pc is getting very hot and there's a noticeable drop it performance in the form of (occasional) very short freezes/jolts. The side of my case is noticeably hot to the touch which also getting pretty loud (HW Motitor is saying under about 50 degrees though) and my gpu is radiating a lot of heat. Is my current configuration adequate?
I have be quiet! Silent Wings 3 140mm PWM x2 spare which could be fitted as extra extractors along the top? But my real question I suppose is with regards to the front intakes, are they likely to be pulling enough air in?
Thanks a lot.
