- 26 Apr 2004
- Milton Keynes
As it stands, I think I'm hitting the limits of my case and cooling setup however would appreciate you feedback!
I have an Antec 300 with the following fans:
140mm top fan set as exhaust
Overclockers H2Flow Extreme AIO cooler, with 2 fans, set to intake.
2x 120mm front fans set to intake
1x side fan set to intake
Thermal Paste is Kryonaut
My GPU is a Powercolor PCS+ so doesn't exhaust all heat out the case.
To push my CPU any further needs some fairly hefty voltage jumps to get stable, and is pushing my temps way too high under IBT to the point of throttling, so realistically I need to cut temps somehow, and realistically throwing a lot of money at a more extreme cooling setup seems silly for the gains, but if there are simple/cost effective/low-risk tweaks, then I'm all ears
