Is my CPU a bottle Neck for my Graphics Card?
29 Sep 2005
Hi Guys,
I have an e6750 running at 2.66 and a Geforce GTX 285
I play games at 1900x1200 - is my CPU holding back the performace of my graphics card?
If so, do you have any suggestions for a noticeable upgrade that wont be overkill?
Cheers,
Monkeh
If the games you are playing ATM are fine then I wouldn't worry about it too much. If even if you OC slightly you'll definitely see some gains in performance. Getting it to 3Ghz shouldn't be a problem and normal cooling should be adequate.
