Hi all,
Just recently I've been having a load of problems with my PC refusing to boot when I switch it on. I hear the drives spin up but nothing else happens, not even any post error beeps. I switch it off, leave it a while (sometimes I also give the CPU a little 'tap') and try again. When it eventually springs into life I notice that the CPU (a P4-3Ghz) speed is sometimes reported as only 1.4Ghz or 2.4Ghz!! Indeed, if I then run CPU-Z it confirms the processor speed as 1499Mhz or 2398Mhz!!
I don't know if its the mobo (Asus P4C800-E Delux) or the CPU giving out, but I also noticed that CPUz reported some quite worrying figures on other aspects of the system and memory :-
When BIOS reported CPU at 1.4Ghz, CPUz reported :-
Core Speed @ 1499Mhz, Multiplier@x15, Bus Speed@100Mhz, FSB@400Mhz, DRAM Frequency @ 133Mhz, FSB
RAM 3:4, Timings 2-2-2-6
When BIOS reported CPU at 1.6Ghz :-
Core speed @ 1600Mhz, Multiplier@x8, Bus Speed@200, FSB@800, DRAM Freq@200, FSB
RAM 1:1, Timings 2.5-3-3-6
The mobo is set to 'standard' overclock meaning 'dont do anything', so does anyone have any ideas as to whether its a mobo or CPU issue?
RAM 3:4, Timings 2-2-2-6When BIOS reported CPU at 1.6Ghz :-
RAM 1:1, Timings 2.5-3-3-6The mobo is set to 'standard' overclock meaning 'dont do anything', so does anyone have any ideas as to whether its a mobo or CPU issue?
