- 21 Feb 2010
- UK
Need some advice, please.
My computer is coming up to 7 years old, and I think the CPU might be failing.
When the motherboard boots it gets stuck on some codes(B6) indefinitely and I have to restart it to get it to boot (sometimes 20-30 times.)
Now the file explorer is slow and clicks can take a while to work or just refuse to work.
I don't think the mobo is dying as it works when I get into bios. I think the CPU is on the way out.
It's like me in the morning very sluggish.
Does this sound like a CPU failure? I am guessing the only way to fix it would be to buy a new CPU or most likely Upgrade everything.
CPU i7-5820k
Mobo Asus x99 Pro
Ram Corsair
thanks for any insight
CPU i7-5820k
Mobo Asus x99 Pro
Ram Corsair
