Is my CPU overvoltaged?
29 Jun 2004
Hi there. I built this system last year March:
AMD Athlon 64 3200 Winchester
DFI UT NF4 Lan Party
GeIL Value RAM 1024mb (1gb) CAS2.5
HIS Excalibur x800xl iTurbo
Samsung 160gb Spinpoint HDD
Here's an image of my volts:
I've been told my CPU Voltage is too high. Its meant to be rated at 1.4V and i've got it at 1.53V. Everything is at stock and nothing overclocked. I haven't got any problems with my CPU but it would help if I could under volt the chip to its recommended settings.
Is my CPU voltage too high?
Many thanks :)
Winchester 3200+ is also 1.4V. I would doublecheck that the reading in the BIOS (& CPU-z) is also that high and if so that the Vcore is set to auto. 1.53V is only really for high levels of OC with a good cooler. What are your temps?
My temps on the image boofuk. Everything is set to auto. My cooler is the Thermalright XP-90.
I meant to ask for the Max temps under load - the ones in the image look like idle. As CPU-z reports lower I would agree with the above and not worry. As I said look at what it says for the vcore in the BIOS (in health screen I would think).
CPU-Z is reporting the right voltage, the Nvidia software isn't great, just ignore it :)
If you're really concerned check in your hardware monitor tab in the bios.
DFI dont recomend using software to read the voltages.. just use them as a guide to fluctuation.
I have a multimeter on order so i can check my voltages.
