- 1 Dec 2009
- Staffordshire
Pretty sure your picture shows your setup working properly, provided the first card actually moves rather than just sticks on 49%.
L4D2
Mafia 2
Fallout 3
1. Search other forums to see if it's used elsewhere
http://www.overclock.net/t/676866/5770-crossfire-only-using-1-gpu/10#post_8581175
I have found a few
2. Try disabling ULPS
Regedit etc
3. That shot looks awful mate. Like an XBOX!
overclock.net - I am having a similar problem. I am not sure both of my 5770's are being utilized. Crysis ran in such a way as to make me want to throw up, and even Battlefield BC2 seems laggy.
One disconcerting thing I've found is that in CCC, if I go down to overdrive it shows both cards. The first card is clocked at idle 157/300, but if I switch to the second card, everything is zeroed out. Should my second card be idling at 0/0?
LtMatt, I am sure I suggested it above? Although you did suggest a quick fix
Sigh![]()
