We've got some work ongoing on our house and due to gutting a few of the rooms we need an electrician to piece some things back together. It's a timber frame house. Just wondering if anyone with some home electrical installation experience can sense check the below.
The electrician I've been speaking to was used by the carpenters who have done the majority of the work to make-safe the electrics around the parts that needed structurally redoing, that was all fine.
We now need new cable running for light fittings, and power sockets for 2 rooms, and according to him, a new consumer unit. Electrician has said that he'll work on day rate (I'm happy with £45/hour) but can't provide an estimate of hours as he'll need to test some existing wiring as well as the new installs, but asked for £1500 up front, which seems quite punchy. I always thought 25% was an upper limit for a deposit (if any), and I am not expecting the work to come to £6000.
Regarding the CU he's recommending a totally new one, which is likely fair play as it doesn't look that new, and we are a timber frame building. Here's the existing unit. I can see there's an RCD and circuit breakers on each circuit, so probably not the most ancient installation in the country.
However when I queried the fact that the estimate for materials seemed high - the £1500 deposit was supposed to cover one day's labour and materials (so materials = 1500 - 8 * 45 = 1140), he has got a bit defensive over types of circuit breakers etc. Even the most expensive populated CU I can find on screwfix is £245 (which is full of RCBOs), so another £900 on wiring and fixtures and fittings - which we won't be going super high spec on or anything - seems excessive. He then pushed back saying type C RCBO's are much more expensive than type B. I googled this an it seems type C are for commercial use and aren't actually any safer, they can just handle higher surges without tripping. At this point he said he doesn't want to get into discussions over types of RCDs and their applications. And then said I should check with insurance to see if I need AFDD's (which are even more expensive) as we're timber frame.
I can't tell if
Sanity check please!
I can't tell if
- not providing an estimate on hours
- a seemingly very high deposit (that he could substantiate with an itemised list of materials but hasn't)
- insisting on what seem like higher spec items without being happy to give me justification
- not being happy to engage in discussion over equipment, and in general not being very convincing over requirements
