9 Apr 2006 at 12:41 #1 geeza geeza Suspended Joined 30 Aug 2004 Posts 9,206 As title. Is there anything else I can try to get a speedbump?
9 Apr 2006 at 12:46 #2 Jokester Jokester Don Joined 7 Aug 2003 Posts 44,968 Location Aberdeenshire No, it's on 9/10, you need to change the 180 (DRAM/FSB 9/10) to 200 (top of second image). Jokester
9 Apr 2006 at 13:34 #3 geeza geeza Suspended OP Joined 30 Aug 2004 Posts 9,206 Jokester said: No, it's on 9/10, you need to change the 180 (DRAM/FSB 9/10) to 200 (top of second image). Jokester Click to expand... thanks. sorry mate. i asked the wrong thing, i know its not 1:1 because it wont do 280mhz. is it on 1T?
9 Apr 2006 at 13:39 #4 Jokester Jokester Don Joined 7 Aug 2003 Posts 44,968 Location Aberdeenshire Command per Clock is set to Auto (so it should be 1T), but set it to 1T to make sure. Jokester
9 Apr 2006 at 14:18 #5 geeza geeza Suspended OP Joined 30 Aug 2004 Posts 9,206 yeh i thought it was the command per clock. this can only be changed from auto to disabled and enabled though
9 Apr 2006 at 14:29 #6 mc_bob mc_bob Permabanned Joined 29 Aug 2005 Posts 1,552 Location Reppin' up North London The new CPU-Z can tell you. Its under the memory tab. If its not try changing those settings and checking with CPU-Z. I think its version 1.33. MC_Bob
9 Apr 2006 at 14:35 #7 Jokester Jokester Don Joined 7 Aug 2003 Posts 44,968 Location Aberdeenshire geeza said: yeh i thought it was the command per clock. this can only be changed from auto to disabled and enabled though Click to expand... Ahh, sorry, make sure it's enabled. Jokester
9 Apr 2006 at 15:40 #8 geeza geeza Suspended OP Joined 30 Aug 2004 Posts 9,206 thanks jokester and bob, i left it on auto and checked with the new cpu-z. it isays command rate: 1T. good stuff
9 Apr 2006 at 15:48 #9 mc_bob mc_bob Permabanned Joined 29 Aug 2005 Posts 1,552 Location Reppin' up North London Nice one. MC_Bob
