Hi,
I'm currently using a Dell U2412M 1920 x 1200 LED monitor and a Sony 40" 1920 x 1080 TV both connected to my GTX 460 1GB
I am thinking about possibly moving the TV into another room, and then getting another U2412M.
Will my GFX card be suitable to run two U2412M 1920 x 1200 monitors? It has two DVI connections (same connection as U2412M), but I mean will it have the 'power' to run them?
As it is currently working fine (with TV and monitor) I am assuming that it will be fine, just wanted to check
Hope you can help,
Hope you can help,
