so installed a cheapo thermaltake AIO cooler and plugged the RGB 3 pin cable into the 3 pin header, the pump just flickered, and the 2 fans partialy lit. couldnt control them with RGB fusion, tried the included sata controller, and the pump leds worked but not the fans. so i RMA;d the cooler and ordered a normal air cooler and some FANs.. so the fans are doing exactly the same thing they are only partially lit in some random colour.
