Is my graphics card to blame?
30 Jan 2005
Following a system crash my PC wont reboot.
I am getting no display on my monitor. I have unplugged the DVI connector at the graphics card and the monitor gives the 'no source detected' message.
I've taken the graphics card out of the machine, cleaned it and reseated it, but still no joy. There is no problem with power to the graphics card as the fan runs with no issues.
Is it likely that the graphics card is faulty? If so what would be a decent replacement for my system?
Intel Core 2 DUO LGA775 E6600 2.40GHz Retail
Asus P5K Deluxe WiFi
2GB Corsair XMS2-6400C4 DDR2 Dual Channel
Sapphire ATI Radeon X1950 Pro 256MB GDDR3 HDTV/Dual DVI (PCI-Express)
Antec NeoHE 550W Modular ATX2.0 PSU
Samsung Syncmaster 191T
Are you overclocked at all, try doing CMOS reset and removing one stick of RAM if that still fails try another stick - just make sure your memory is not coursing any problems.
Is there any possibility in checking your gpu in another pc.
Hi im having a similar problem, Fairly new to this though
Just built a new computer and connected it up to a monitor first....nothing so tried a tv, using VGA, cant seem to get anything up at all
Power LED is on, all fans working
Spec:
Antec 900
P43 Neo-F motherboard
4gb OCZ PC-8500
1tb Samsung HDD
XFX 9400 1gb graphics card
Q6600 processor
Any ideas guys?
Thankyou in advance.
Are all power cables in, including the 4 or 8 pin for cpu power.
Have tried what I said to the op regards memory and doing a CMOS reset.
