I brought a second hand power supply and thought I'd test it with a bunch of spares I have lying around. System powered up fine and I was just leaving heaven benchmark looping as to draw some power to see if the PSU coped ok.
I started getting crashes of Heaven. I could get it to crash faster by upping the power limit in afterburner until the point now where all I get is a black screen. The computer passes POST slowly, it hangs on VGA for a while before booting into windows. It does boot to windows as I can hear the log in sounds.
I have tried an old known working PSU with the same outcome.
A known working GPU and I get an image and boot to windows.
If I put the GTX 1070 into my main PC I get the same black screen but it does actually make it to windows
I have tried resetting BIOS also tried TV and monitor and HDMI and display port.
I can't think of anything else to try.
Now if it has died on me, I have no way of knowing if this new(second hand) PSU killed it and I should not risk any more equipment with it or if its just a coincidence and for whatever reason the GPU didn't like being sat in a box a long time and then put under strain.
Test system was
Ryzen 5 2600
MSI b450 carbon pro
16GB
GTX 1070
all stock
Can anyone suggest anything else to try before I strip the card apart and look for physical damage?
EDIT*
Update. I switched over to my onboard a put the GTX 1070 in and in device manager it has an exclamation mark next to it. Properties tells me windows has stopped the device with error code 43.
I've stripped it down and the TIM was terrible. Temps were ok though when running heaven earlier they were low 70's
I'm wondering with so much of the die without TIM on (this was the factory stuff I had to remove the warranty sticker and I brought the card new) if maybe somewhere has overheated and broken. Even has a nice hair right in the middle!
Test system was
Ryzen 5 2600
MSI b450 carbon pro
16GB
GTX 1070
all stock
EDIT*
