Just got a brand new Gigabyte GTX 780 and its doing this...
free uploader
Is it safe to assume that it is faulty?
free uploader
Reseated the card? Changed the slot? Correct power cables etc?
That looks like a card memory fault or a faulty PSU.
Check your power supply?
If not its broke return it.
Actually some times it can be the BIOS acting up at post ! I've seen it with a GTX 660 before. No artifacts in windows or when gaming nor within the BIOS itself but just during POST.
Some times a BIOS update fixes it.
Does the anomally also occur in windows and when in the BIOS itself ? If so then yes it's defective vram.
Def looks faulty.. It has done this since you first installed it?
