Is My (intended) Loop Order O.k.?
4 Dec 2009
Worcestershire
I am planning to go Res-Pump-GPU-CPU-Rad-Res. Is this loop order o.k.? I have seen some posts saying I should have the CPU before the GPU but it would look so much nicer and less messy if I had the GPU first.
I am running a 5850 (overclocked) and a Phenom II 955 (overclocked).
Thanks.
tbh it makes no difference to loop order, apart from res needs to supply the pump (thus needs to sit before the pumps inlet).
just go with what keeps the loop shortest
Hmm, I've just had a thought. The whole point of having res before pump is to ensure pump doesn't run dry. But surely then you could put rad before pump, as the rad will ultimately have a greater capacity than the pump.
A main advantage of res before pump is that you can see the level of water in the res as you are filling the loop so you know when to blip the psu. Kind of hard to do this with a rad :)
Loop order is fine, providing you've got the res before the pump your fine. The rest of the loop will reach equilibrium fairly quickly.
