- 6 Sep 2019
Hi guys,
I am building a new PC and plan to reuse some of the components from my old machine. The PC currently has 64GB of DDR4 RAM (8 x 8GB sticks) and i plan to take across 32GB of it (4 x 8GB sticks)
Before i go buying parts for my new build i wanted to check that it will be compatible first, and i am not sure. (Googled the hell out of it and i am not getting a clear answer)
The brand of the RAM is Crucial and the model of RAM i currently have is:
BLS8G4D240FSE
I have done a check on the Crucial site with the motherboard i want to buy which is a Asus ROG Strix X570-I Gaming Mini ITX AM4 Motherboard and it states the following RAM is compatible:
BLS8G4D240FSEK
The Crucial site does NOT state that BLS8G4D240FSE is compatible, it doesn't say it isn't either
On the Crucial site the only difference it mentions is one is Dual Rank (the one i have)
The one on the crucial site ending with the letter K is single rank and that one that is listed as compatible.
Will the RAM i have work? (BLS8G4D240FSE)
Thanks
BLS8G4D240FSE
BLS8G4D240FSEK
Thanks
