- 17 Dec 2004
- Crawley, WEST SUSSEX
Hi,
Ok I have the Gskills 2GB HZ PC4000 memory and have had no problems to date. Now I started to overclock my Opteron 146 a few days ago. Got it to boot into windows at 3ghz but it didn't pass OCCT, then tried 2.9GHz it passed OCCT but wasn't prime stable. So thought it might be my memory becuase in the DFI bios I had all the settings on Auto.
So changed all the settings to what Gskills recommend on there webpage and ran memtest, on 3ghz i was getting errors so lowered the cpu to 2.85ghz and i got a lot of errors. So decided to reset all the bios settings to what they were before overclocking. To do this I used the CMOS Reloaded and then the computer wouldn't even post
So cleared cmos unplugged the psu and restarted and it now boots. So with all the settings at auto etc in bios i ran memtest again and got no errors for 2+hrs. Now i have just entered all the correct standard settings, these i got from the gskills website (they had an image of there settings when overclocking a 3000). So I ran memtest and got an error at test 7. I then have upped the voltage to the chip and the cpu (Memory = 2.8v CPU = 1.5v) and got an error on test 3 after 1.30mins.
Does this mean my memory is faulty?? Or should i try some other tests?
