PC turned itself off today - I thought it was a power cut, but all other power was working. I changed the power cord for one that I know works and tried to power on but it won't power on.
Opened the case, when I press the power switch the CPU fan moves about 1mm (probably less) and then remains motionless. I had a spare power supply, so I swapped that out. Still dead. I then thought maybe the switch? So I pulled out the wires to the front of the case and tried to power on with a screwdriver (like a breadboard setup). Still dead.
Specs
CPU AMD A10-5800K Black Edition 3.80GHz
Mobo: Gigabyte F2A75M-HD2 AMD A75 Chipset (Socket FM2) DDR3
Memory: TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz
Power Supply XFX Pro 450W Core Edition '80 Plus Bronze'
Also tried Corsair 430W
Any ideas which component could be dead? Mobo? Memory? I purchased the whole thing from overclockers six months ago.
Specs
