Is my monitor knackered? : Single vertical line appeared
4 Feb 2004
Écosse
I posted about something similar happening a while back on my PC, its still the same system and monitor I was using in this thread:-
http://forums.overclockers.co.uk/showthread.php?t=18049684&highlight=monitor+username_Draeger
Unfortunately the same thing has returned but this time it doesn't look like wiggling the cable or unplugging everything and putting it all back together again is making any difference:-
It also shows the same pink line when the VGA cable is removed and also in the BIOS setup screen. I've tried a brand new VGA cable as well, no joy. Is it completely knackered?. :confused: :(
If the lines were random on the screen i would have said GPU problem. but if its stuck there ur monitor is most likely fubarred.
any warranty left on it?
Nah, it's served me reasonably well. It's about 5 years old, an Octigen 19" Widescreen job. Cost about £60 new back then so not too much of a disaster. Excuse for an upgrade I guess. :)
Annoying though since it did the same years ago when I posted that first thread and I managed to fix it in a few minutes by just unplugging the cables and putting them back in again.
It may be a loose connection in the back of the monitor itself so you unplugging and reconnecting may of moved a pin or something back to it's original position, however now the monitor is older it may not be able to due to wear and tear.
Upgrade? Yes :).
Might be worth a pop taking the back off it and seeing if it can be jiggery pokeried around with and persuaded to 'work' again. :p
At least until I decide what upgrade to go for.
I had something like that on my Samsung 2443BW, had to send it in for repairs.
Started off with a single vertical line, as time went on I got more and more lines, Samsung fixed it by replacing some of the electronics it seems as I still have a dead pixel at the same spot as when I sent it in :P
pink line makes me think gpu - can you change resolution or something to see if the line moves?
I'll give that a whirl and see. To be fair, I've not tried the monitor on another desktop PC yet to discount the possibility that its the GPU. I'll do that too. :cool:
The bootscreen/windows start animation are already in a different resolution, I'm 99% sure the problem is with your monitor.
As said above test everything if you can
I would say the monitor is ****ed, but before you upgrade make sure it is the monitor
If you have had it for that long an upgrade would be nice
Yeah, tried a brand new VGA cable with no success, pink line in exactly the same position. I'll try the monitor on another PC and see if its still there.
