Hello.
I bought this switch in March of last year:
https://www.amazon.co.uk/NETGEAR-GS208-100UKS-Gigabit-Ethernet-Desktop/dp/B00AFVB41S?th=1
and have had no problems with it - mixture of RPis, desktops and a server/NAS all running fine.
I bought this particular SAT>IP Server:
Sat-IP server Telestar DIGIBIT R1 SAT2IP Umsetzer from Conrad Electronic UK
A few months, but I could not get it to connect to my network, so I sent it back on the basis of it being faulty.
I recently re-ordered the same device and encountered the exact same problems - i.e. it just would not connect to my home network.
I then realised that it had to be something other than the SAT>IP Server.
I experimented with 15 different Cat5e leads (varying lengths and qualities) and not a single one made a difference.
I then tried a very old and very long Cat6 lead and the SAT>IP Server immediately connected.
I asked, on a few forums, whether the SAT>IP Server only worked with Cat6 cable and was told that it should work with just about anything.
I did more testing and tried plugging the SAT>IP directly into my router instead - immediately connected.
By process of elimination, therefore, I realised that it is my switch not playing ball with the SAT>IP server, when used with Cat5e cable.
Do you think it is faulty?
It is an unmanaged switch, so there (as far as I can tell) no options to play with to improve the situation.
What do you guys think?
