The problem is the reset of different drivers after error message
"The display driver has stopped responding & has been reset"
This happens while running FAH & Seti cuda units. When starting a new WU, not always, with FAH or resuming SETI.
I have tried 2 different drivers, clean install, & problem reoccurs.
If I drop the o/c or even run @ default problem can occur.
Sometimes a reboot or 2 solves the problem or stopping FAH & then running SETI [sometimes have to restart BOINC].
In recent days have had screen lock up which have either required a reset or Windows has restarted itself. This happens even if I have my monitor connected to the iGPU of my i53750K.
Other times it can run for days without a problem
I d/l Furmark 1.6 & that ran ok but then found a new version 1.10. Just tried to run it @ default & the display driver crashed the program.
This is a RMA replacement 560Ti card [came in a plain box no accesories]
Previously I tried different PCI-e power connectors without any effect.
I have turned off the sidebar gadget & changed power plan to high performace
Short of trying a different PCI-e slot on the new mobo what else can I try? Or should I just request an RMA?
Thanks for any help/advice
