Is my Overclock OK?
29 Nov 2019
I have built myself a new PC, Specs:
6600k, 16gb 3200Mhz RAM, GTX1080, Z170E Mobo, 6 case fans and a 212 evo.
Following a LTT video, I turned "XMP" on, changed my multiplier to 46 and my core voltage to 1.35v. My system seems stable, and the cpu doesn't go higher than 70 degrees. Just want to see if there's anything I've done wrong. According to CPU-Z my voltage is 1.376v.
Finally, when I turned on XMP, it set my RAM speed to 3200Mhz (What it says on my RAM sticks) and my DRAM voltage to 1.350v. I haven't touched either of these settings. Does that mean my RAM is overclocked now?
Best use something like Speccy or CPU-Z and check clock and RAM speeds for yourself.
Sounds like a fairly high voltage for that clock speed but not dangerous. Just might cool down at a lower voltage.
