Hi guys,
I was after a little advice. I have a 250gb WD Sata drive in my PC that has been flawless for the past 4 years, however about a month ago I would be surfing the web or gaming and all of a sudden I would hear what sounded like something losing all power and turning off, then my PC would blue screen and boot up every now and then.
This happened several times until it has now stopped booting all together, and after the windows loading screen comes up, the hdd makes the same noise (likes it's lost all power and shuts down* and it get the bsod.
I thought I was then screwed and would need to buy a replacement hdd, but I pinched a 40gb sata disk from work and plumbed that in under Sata 1 and installed Windows, and the "broken" hdd as Sata 2.
I am now back into Windows and I can see the "broken" hdd and navigate through it fine....
Therefore my question is what the heck is up with it if I can't boot from it, but I can install it as a secondary drive and it works fine.
Does that mean it's on its way out...
Any guidance would be great
