My pc seems to be running fine but today when I checked HW monitor my 12v line is listed as 11.176v
Have a Fury X and 4790K @ 4.7Ghz
PSU is a EVGA SuperNova G2 750W '80 Plus Gold' and is 3 years old
it will be under guarantee though wont it
if in doubt you can always downlaod hwinfo64 its a lot better at reading sensors, after you've installed it scroll down around halfway until you see you mobo with in there are the 12v, 5v and 3.3v read outs, place you system under load and keep hwinfo open after a while go back to it and see what voltages are being reported, from memory the max tolorance from atx is around 11.6 minimum, if your at 11.1v then alarm bells should be ringing
