Recently built my new machine and it's not been happy since day one really, once a day (randomly), most days, it will just reboot itself for no reason, it's not showing any BSOD either as I set it to not automatically reboot.
I have run a memtest to check to make sure the RAM isn't at fault and it comes back all clear, temps are respectable in the 40s (it has rebooted when the computer was idle).
The hardware that has changed from old pc to new is RAM/CPU/Mobo/SSD so I don't know, I suppose I could try running without any of the additional hdds. I've also updated to the latest BIOS a couple of times on the mobo as the changelog stated "improve system stability" but it didn't make any difference.
So, does 500watts sound like enough for my setup? Is there a sure fire way to figure out if I'm pushing the PSU? Do we think it could be anything else?
PC Spec:
Intel i3 2120
Asus P8Z68V PRO
4GB pc12800
1 x aDATA s510 SSD
1 x WD 1.5Tb
2 x WD 500Gb
Nvidia GTX 260
USB = Mouse/Keyboard/Printer/MCE receiver
Thermaltake T2 500watt
It's been a while since I've had any problems with my PC and I'm disappointed my new build isn't as reliable as my old
PC Spec:
Intel i3 2120
Asus P8Z68V PRO
4GB pc12800
1 x aDATA s510 SSD
1 x WD 1.5Tb
2 x WD 500Gb
Nvidia GTX 260
