28 Jun 2010 at 19:36 #1 dmcg dmcg Soldato Joined 5 Jul 2009 Posts 3,704 My PSU seems to pop a lot when I switch it on is it a sign of its incoming death ?
28 Jun 2010 at 19:46 #2 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent Does not sound good, double check the mains socket - but ignore if already done. What PSU are you using?
28 Jun 2010 at 19:47 #3 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare oh dear. make and model please.
28 Jun 2010 at 19:51 #4 dmcg dmcg Soldato OP Joined 5 Jul 2009 Posts 3,704 it's a Corsair TX 650W had it since last july
28 Jun 2010 at 19:53 #5 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare surprising. give the kettle lead a wiggle, and the large motherboard connector
28 Jun 2010 at 19:55 #6 dmcg dmcg Soldato OP Joined 5 Jul 2009 Posts 3,704 it might be a bit dusty but not too bad maybe thats why? it works fine but just makes a pop noise quite often when its switched on Last edited: 28 Jun 2010
28 Jun 2010 at 19:59 #7 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare good warranty with corsair, RMA it.
28 Jun 2010 at 20:23 #8 pooley pooley Soldato Joined 11 Jun 2010 Posts 3,955 Location In the dwelling rma time methinks, better to be safe than sorry!
28 Jun 2010 at 23:04 #9 dmcg dmcg Soldato OP Joined 5 Jul 2009 Posts 3,704 pooley said: rma time methinks, better to be safe than sorry! Click to expand... yep just sent the form waiting for the reply thanks , tho I dont have much of the stuff that was in the box only the protective foam and the box ofc
28 Jun 2010 at 23:45 #10 weegill weegill Associate Joined 31 May 2009 Posts 70 they'll only want the unit and the box so dont worry about anything else
