Is my PSU dying
10 Mar 2012
After I switch off pc I will swit it off at the wall socket as my speakers are buzzing when on. Now the issue is when I power it on, I will see AsRock logo fans will rev up and then it will go black screen no signal and back on. Previously it happened only once now it does it twice and third time it will start as normal I only press power button once. However if I don't switch it off at the socket, restarting or switching on and off it will power on without any issues. Im not sure if it's my mob or psu. I had this psu for a long time I think around 9 years.
Specs
- Asrock steel legend b450
- Ryzen 5600
- Vengeance RGB PRO Black 32GB (2x16GB) 3600MHz running at 3200
- Superflower HX Green Gold 550W
- RTX 4060 Ti now and RTX 2060 Super previously, same issue with both.
