Ok its pretty simple atm. I have am amd phenom, 8gb ram, 7900gtx, and 6hds. thinking of getting 2 more hds. I currently have a 650w psu. Is this enough?
I have an arm full of sata converters (power), power splitters, and sata data cables lying around because I have them left over from other mobos, so yeah luckily also the mobo only has 2 sata connectors but I have some pci cards. One I am using atm does full sataII, the other I will use for these is only sataI, but I will put some full hds on those and the new empties on the mobo.
plenty if its good brand one otherwise i will consider something good like thermaltake/enermax/tagan/seasonic/corsair and such, not even for the power but for safety. I wouldnt run 8HDDs on cheap PSU, if it dies it will take all of them with it.
