Seasonic G series 750w 80 plus gold
CPU 4670 none K
4x4GB 1866 1.5v
750 HDD 250 SSD
2xR9 290 (only one now but adding a second soon)
2x10w DDC pumps
Run of the mill keyboard and mouse
6x AC120mm fans @50% fixed.
Can't think of any other drain on the psu, do I need to go bigger on the psu, amd say 600w minimum for system plus one card and they spec 260w each. But a lot of online tester's say system with one card pulls 300 to 400 at the wall with a Overclock my system is not over clocked. And the second card would only add around 70% more gpu load so max would be ???? 600-650w if the online test ppl are right. What your view
CPU 4670 none K
4x4GB 1866 1.5v
750 HDD 250 SSD
2x10w DDC pumps
