- 20 Apr 2004
- Rugby
Short version: Lots of random restarts, eps when GPU and CPU is loaded, system restarts after less than 5mins of memtest in dos with a single stick of ram. Noticed in windows and the bios the 3.3v rail is idling at 3.12v drooping under 3v seeing as low as 2.89v
Psu is a 5 year old just out of warranty (as of November 4th) Seasonic based Coolermaster V1000 purchased from the forest
Long story: Came home last night after a long day to play some BF4, but system random rebooted , oh I though, same happened again within 5 mins, then a thrid time booting into windows (BSOD), then when idling at windows.
unpluged the PSU, pressed the power button reset my bios so i was at stock as my hand me down 8pack X99 OC Formula is a quirky beast.
When I got into windows I did a aida64 stress test with everything but the GPU, seemed fine for 5mins, switched on the gpu and the rebooted in under 3mins. I was starting to think it was the GPU more than anything else. Then I did abit of mining on just the GPU, was solid for 30mins+... odd. Played some BF4 and again it rebooted within 10mins no BSOD, maybe it was the ram i though.
Temps where fine (custom water) check HWmoniter and the asrock software 12v/5v rails looked fine but the 3.3v rail was abit low at 3.12v ish at idle. I would also see it drop as low as 2.9/2.85v for more than a second before returning to the low 3v/3.1v hmmm.
booted the UBCD on a usb stick with a single stick of ram and BOOM restarted within 5mins, the next time with more all 4 sticks with in 10min.
As the 3.3v rail feed the ram I'm starting to think its not the ram or the gpu but the PSU
