Is my psu powerful enough to power a new system?
3 Nov 2006
Hi guys, I've been looking into a christmas upgrade (you have to make yourself happy before you can do the same for others :rolleyes: ) and I was just wondering what your thoughts were on the psu I would need to power the following spec:
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN)
£99.99 £99.99
MB-061-GI Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI)
£89.99 £89.99
MY-058-GL GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
£139.99 £139.99
GX-025-BG BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-025-BG)
£84.99 £84.99
HS-000-SB Tuniq Tower 120 CPU Cooler (HS-000-SB)
£28.99 £28.99
Subtotal £443.95
VAT £77.70
Total £521.65
In my current system I have an intel 385W jobby, would that be enough?
Thanks in advance for all of your help
Jonny
Sorry for the lack of information in my first post, I'm not very knowledgable about psus. So, there is a sticker on the side of my psu that says:
AC Input | 230 Vac 50Hz 8A
_______________________________________________
DC Output | +3.3V | +5V | +12V | -5V | -12V | +5Vsb |
Max.A | 35A | 36A | 18A | 1A | 1A | 2A |
+5V & 3.3V Combined 220W Total Output 385W
Intel Ver1.3 ready
ATX 12V
Hope this helps, thanks a lot for all the help
Jonny
A new PSU would be a good idea, you're PSU only has 1 12v rail, most have 2 or 3 now adays to feed the graphics cards. I think your card will also need a PCIe connector, which your PSU doesn't have - though I think you can get a converter. Still I wouldn't like to try that one with only 18A on the 12v rail, its pushing it I'd say.
(edit: you'll also need the 24pin atx, but you're PSU doesn't have that either, with early boards you could get away with 20pins but I don't know what the situation is now adays, is it really worth risking £530 of gear though?)
Thanks for your quick replies and your right it's probably not a good idea to risk £530 worth of gear, especially as I'm skint.
Could you recommend me a good powersupply to power this little lot that would be future proof, and cost around the £60 inc VAT mark?
Thanks for all of your help
Jonny
you might be pushing it. But only running a 7600GT, and if you're not OCing then you should get away with it. But looking at your spec, i'm guessing you're gonna be OCing. New PSU time.
Don't buy something **** though
Yep, I really wanna do some OCing with that little beast of a cpu, what would you recommend in terms of the psu, I would go for a Hiper but I have heard bad things about them.
Thanks Jonny
If you're going to be overclocking I would get a new PSU, if you weren't you would probably be ok with that.
Jokester
Thanks Jonny
tagan, seasonic, enermax, FSP are well trusted brands for PSUs
