Hi all,
I have my i5 2500k overclocked to 4.6ghz and it runs prime 95 stable for 48hrs.
The VTX 7970 I have is set at stock.
The problem I am having is when I load up Max Payne 3 the system crashes and restarts, no BSOD, it's as if someone turned off the power.
I have swapped out the 7970 for an old 2900xt that I have and the computer still does the same.
All other games and software run fine including BF3 on ultra settings.
When Max Payne launches I can hear a noise that sounds like an old dial up modem, it appears to be coming from the psu.
If I remove the overclock the noise is still there when launching Max Payne but the game will play.
The psu I have is an OCZ 780w modxstream and its just over three years old.
Is it possible my psu is on its last legs ?
Any help much appreciated.
