is my PSU up to it!
17 Mar 2006
I have an Antec 350w Smart power PSU and it currently running a 3Ghz P4 478, 6600GT, 2 hard drives, 2 optical drives without problems but i'm thinking about overclocking the gfx card and cpu i know the 350w is more than likey on the borderline but how can i tell how far i can push it, what should i be looking for?
any ideas?
I think you are right about being borderline, there is no surefire way to tell, PSU calculators might give a rough idea but I'd be more inclined to check your voltage rails in a hardware monitoring program such as motherboard monitor. If there are any significant fluctuations then you are probably overloading your PSU.
Its an Antec PSU - You should be fine for Overclocking with that IMHO.
If you notice stability issues appearing, then reduce the clocks a bit.
Remember than an Antec 350W is equivalent to a 600W Q-Tec!
thanks for the advice.
I'm now running the 3Ghz P4 at 3.2Ghz and i've overclocked the graphics cardaround 10%, Have monitored the voltages while benchmarking and gaming and they seem to be very stable.
