when tightening the right barb, the plastic casing suddenly cracked slightly, so i undid the barb a little but now have a slight crack. it appears to be only hairline you can see it a bit in the picture. i will leak test this, but do you guys think it'll pass? the crack has reached the outside, but i dont think it has penetrated the inside.
thanks
daven
thanks
daven
Even if there is a crack a bit of epoxy on the outside should seal it again.
