ok so im about the put my system together, but while looking for some water cooling stuff and fans i come across a gigabyte g1 sniper 3 and then noticed the m3 version
i currently have a ga-z77-d3h which i though was best suited for what i needed at the time of buying it,
so now i have all that fun stuff sorted, i'm now curious about this g1.sniper boards
i have compared the boards but wondered if these is any noticeable difference other then the 2 way and 4 way sli/xfire.
im sure im not going to need more then 2 way, so the question is is it worth getting over what i have currently?
what i have spec wise.
i5-3570k
Corsair Vengeance Pro 1600mhz (2x4gb) will upgrade later if need be....
r9 290,
Corsair RM1000
SanDisk 128gb boot drive
yet to buy hdd, likely 750gb/1tb.
z77-d3h i currently have
and one but soon to buy another 20" screen
win 7 64 bit
so i am looking to over clock the cpu and gpu, the cpu to near max once on water and gpu to moderate levels, likly on stock cooling, unless temps are terrible
at the moment i have a stock air cooler for the cpu. but once every thing is up and running and i know everything is working,
was then going to look at water cooling, not sure if to go closed loop with a single or double rad, or go full system using two 240 rads and do cpu and gpu in a series setup. but thats for another day.
is there any thing else i can change? make better? of would you say im pretty sorted for most games on high
cheers
i5-3570k
r9 290,
Corsair RM1000
win 7 64 bit
cheers
