Ok i have been away from the whole IT technology thing for a few years now so choosing this spec has been a bit hard and im not sure if its good and also will be compatible with each other
Monitor - LG L226WTQ 22" Widescreen LCD Monitor
CPU - Intel Core 2 Duo E6600 "LGA775 Conroe" 2.40GHz
GFX - BFG GeForce 8800 GTS OC2 640MB GDDR3 HDTV/Dual DVI
Mobo - Asus P5K Deluxe WiFi Intel P35
Memory - OCZ 2GB (2 x 1GB) PC2-8500 1066MHz Reaper HPC Edition Dual Channel DDR2
PSU - Hiper HPU-4M730 Type R 730W ATX2.2 PSU
Case - Lian Li PC-A16B Aluminium Full-Tower - Black
DVD-R - Plextor PX800A 18x18 DVD±RW Dual Layer ReWriter
HD - Western Digital Raptor X 150GB WD1500AHFD 10,000RPM SATA 16MB Cache - OEM
If any one could suggest any compatibilities i might get and also if i could have bought anything better i would appreciate it
