- 11 Jan 2011
Hi, I run prime 95 for 8 hours today running small FFTs it showed 0 errors. Is this the best test to use on prime or should I have run large FFTs or blend test?
I was using intelburn but it was giving bad results when run on max settings I read in to this and its because it tests the max amount of available memory not the max amount of free memory. A lot of people have been having this problem and think they're system is unstable.
