Is my temp ok?
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi, well I have just upgraded the fan on my OCZ Vindicator cooler to a Hiper 120mm fan that does 59CFM at 1500RPM, also upgraded my 80mm case fans and stuck the old 120mm fan from the OCZ Vindicator in the front and got me an Coolmaster AeroGate 1 cooler.
Currently my E6600 CPU is at 3.4Ghz, 1.55V, idle temps of around 32-34 degrees and load temps of around 62-64 (Speedfan readings), currently stressing with Orthos.
With 3.2Ghz 1.45V my idle temp is 27-28 degrees, sometimes it spikes to 30 but back down, and load temp is around 55 degrees solid, sometimes also jumps to 56 degrees smetimes.
With the standard OC Vindicator 120mm fan my temps usually got to 69 degrees load at 3.4Ghz 1.55V, and 60 at 3.2Ghz 1.45V, so the temp difference I am very pleased with, also the fact the majority is 80mm fans which are cooling this case, and its not the best case, so that also make me feel these temps are not bad, but I would liek your oppinions.
Thanks
Willz.
Those temps sound fine?
Excellent I'd say!
Although it's not really a good idea to compare two systems temps, what with all the potential variables, the idle figures are better than my temps, and the load only about 5 degrees higher, and I'm using a water setup (Apogee GT block/DDC1-T pump, 240mm rad).
Nothing to worry about there at all, assuming the temps are accurate.
Tooks said:
Excellent I'd say!
Nothing to worry about there at all.
Great :), Just wish my CPU would be stable at 3.4Ghz now :mad:, my NB Core is at 1.74V with 60mm fan on it, and PCU at 1.56V and it still aint happy lol.
