Hi guys
spec in sig
i'm not sure if my xfire is working.
i have xfire enabled in ccc and decided to run furmark to see what scores i get.
i have the latest version which puts 2 icons on my desktop;1 normal and 1 multi gpu. i use the multi-gpu shortcut.
if i disable xfire i get 6000ish points but when enabled i get the same score.
this doesn't seem right to me.
what can i do to diagnose any problems.
and is it something as easy as v-sync.
ta
jobe
spec in sig
ta
jobe
