- 14 Jul 2013
- UK
Hi all I would like some help and advice if possible please. Is my gpu working as it should be?
Full spec in sig!
A few things;
1) Sometimes it will boost to 2025Mhz on the core, other times only 2012Mhz, or lower, why? Also boost is advertised at 1835Mhz?
2) Power consumtion is only at a max of 75%? Why am I not getting 100% at full load?
3) Are my benchmark scores ok?
4) Only used up 1.2GB GPU Memory with 3DMark?
5) My 12v rail is showing a solid constant 12v in HWMonitor, so thats not holding anything back?
6) In 3DMark it shows my GPU clocks as this Clock1633 MHz (1633 MHz) not 2025Mhz?
7) In 3DMark it shows my CPU clock as 3.4Ghz not thr 4.4Ghz OC?
My 3DMark scores are;
Firestrike - http://www.3dmark.com/fs/9529163
Firestrike Extreme - http://www.3dmark.com/fs/9394988
Here is a GPUZ screen with it showing all MAX values while benches have been running;
Any advice much appreciated!
Full spec in sig!
A few things;
