8 Feb 2022 at 17:34 #1 Zarax Zarax Associate Joined 3 May 2021 Posts 1,272 Location Italy Hello, sorry if this is the wrong forum. Since I made an order here I'm receiving daily calls from UK, is there any way to know if it's from OCUK? Thanks!
8 Feb 2022 at 17:56 #2 MissChief MissChief Caporegime Joined 17 Jul 2010 Posts 26,441 The OCUK number is 01782 44 44 55 so if the number is similar, perhaps a digit out then it could be them. Otherwise probably a coincidence.
9 Feb 2022 at 05:31 #3 Zarax Zarax Associate OP Joined 3 May 2021 Posts 1,272 Location Italy Hopefully there is no databreach...
9 Feb 2022 at 11:28 #4 Feek Feek Commissario Joined 16 Oct 2002 Posts 343,127 Location In the radio shack Zarax said: is there any way to know if it's from OCUK? Click to expand... Yes of course there is. Answer the call. If you're concerned, post in here. Zarax said: Hopefully there is no databreach... Click to expand... There is no data breach.
9 Feb 2022 at 12:06 #5 Zarax Zarax Associate OP Joined 3 May 2021 Posts 1,272 Location Italy Feek said: Yes of course there is. Answer the call. Click to expand... I'd rather not answer if I'm not sure, UK numbers calling here (Italy) are usually spam robocalls.
