- 20 Nov 2009
i just bough aload of w/c parts exc. pump,fluid and tubing
it has with it,
a cpu block and bracket,
gpu bloc
north or southbridge
confused
block
and a 120 rad, i was told this wouldnt be enough for all that so im thinking of getting a lancool case to put it all in as my dell xps 625 will struggle to fit it.
ive looked at some 240 rads on ocuk i dont know which one to get,
also can you have 2 rads in one loop, e.g have the liquid pass threw the smaller then bigger one or vise versa
so that i can use up that extra rad.
thanks for any help givin
it has with it,
gpu bloc
