Is something broke?
Permabanned
30 Nov 2008
Manchester
I have an E5200 that had the stock intel cooler; Temps; Idle[43.c] Load[60.c] i was planning on overclocking it a little so i bought an Artic Freezer 7 PRO, the temps are now Idle[43.c] and load[50.c].
Whats worrying me is that the lowest temps from both coolers is 43.c my motherboard is an MSI neo-f P43.
Any ideas?
How would i fix this?
Cant as far as Im aware, stuck sensors seems to be quite common nowadays.
If your temps dont change from an open build to inside ur case I would say your case flow isnt too great, although the fans you listed seem adequate.
From my experience the Artic Freezer 7 PRO isnt that much better than stock cooling, so ur temp drops seem good to me.
