Man of Honour
- 13 Nov 2009
- Northampton
I currently have a custom build home server based on a dual core and chip with an Intel nic running esxi, which then runs FreeNAS and a couple of other vms and currently have 2x1tb drives in a ZFS pool.
The plan is to run an 8 drive array eventually with 2 parity drives. However I'm at a point where my current storage needs are close to exceeding to storage space I have, but I haven't got the funds to drop on 8 drives and a controller card in one go.
I could go out and buy another drive to add to the pool but that presents me with two problems, firstly it means i still haven't got any redundancy and secondly once I have built my 8 drive array the 3+ disks in the pool cannot be added back to the RAIDZ2 array to increase capacity or the number of parity drives.
Is it possible with storage spaces to start with a JBOD type pool of drives then at a later date stick another drive in the system and add that as a parity disk or does it have the same limitation as ZFS whereby once the array is created as a JBOD I'm stuck with it being a JBOD array.
