Is that right?
4 Mar 2006
Macc
My first O/C and I'm not sure if I got everything ok. I ran Prime95 and it was stable (I couldn't force it to start a torture test tho :confused: - I simply can't click that option)
Anyways, my memory's stock timings are 2-5-2-2-1T, and at one point I noticed in BIOS that they got shifted in a wrong kind of way (ie the last timing was 2T), so I moved them to the maximum (?) suggested by the manufacturer (that's 3-8-4-4-1T @ 533 MHz) to see what happens. This in turn changed my CPU's clock (to 266 MHz x 6 if I'm not mistaken). That's where I started playing around. First I brought the multiplier back to x10 (I've set Voltage to AUTO, as I'm not sure what the safe values are), but then memory settings got blocked in automatic position. Turning them back to manual would force the CPU settings to go to AUTO (not sure why).
At one point I did manage to get both on manual and left the 250x10 and 3-8-4-4-1T @ 533MHz settings. This however caused Prime95 to detect a problem very early on. I decided to put my memory back to stock settings but it crashed. Now it's pretty much on automatic (and Prime95 stable), but I'm curious if I can get anything more than 166.7 MHz.
helpimcrap said:
set the timings to the mfrs spec on you memory at stock speeds. and then just use a divider. i think the 166 divider would be best.
back to stock? Last time I did that it crashed, but then again I didn't change the divider - not really sure where to do that
(I checked the BIOS and nowhere can I find either the divider or the FSB for that matter). As I said that's a first time O/C and I may have messed some things up and miss on even more things :P
Oh an don't use the nVidia firewall if you are, its crap
good to know =] ATM I'm using both nVidia and Arcavir firewalls and they're blocking pretty much everything I want to do/download :P
